Re: Freeing a stuck engine on an M
Posted by CHIEFEAVES on June 10, 2008 at 10:21:44 from (64.12.116.73):
In Reply to: Freeing a stuck engine on an M posted by Pat H. on June 09, 2008 at 16:53:05:
I had the same problem on my 39 M. I put a little of everything mentioned above, end result, I removed the head. Removed the rod caps and used a piece of 2 x 4 to tap the rots upward. 1, 2, and 4 came right out. When I tapped no 3 it came out along with the sleeve. The way it was stuck I do not believe anything would have freed it. Did not matter that the sleeve came out for I was going to put new sleeves in anyway. Good luck.
Harley
