Re: H belt pulley oil capacity
Posted by 45 JDB on June 10, 2008 at 11:10:39 from (206.166.230.5):
In Reply to: H belt pulley oil capacity posted by joho on June 10, 2008 at 02:08:51:
There is a round knob located behind and to the right of the belt pulley mounted on the torque tube. Remove this knob, inside should be a dip stick this is also where you fill the resevoir with 30W engine oil until you get the correct reading on the dip stick. Can't remember how much but I think a couple of quarts. It does not fill from or share lub with the differential which takes 90W gear oil.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
