Re: Super H 12 volt conversion
Posted by Bob on June 10, 2008 at 21:02:03 from (69.178.228.68):
In Reply to: Super H 12 volt conversion posted by kidd1954 on June 10, 2008 at 19:55:34:
Since you have reversed the battery ground, you need to swap any and all wires connected to the ammeter posts from one post to the other. Assuming it read correctly BEFORE the ground changeover, it will read correctly AFTER the ground coversion, once the wires are swapped between the ammeter posts.
