Re: Remove a steering wheel on a Farmall H
Posted by Mike Farmer on June 11, 2008 at 08:25:47 from (86.31.82.79):
In Reply to: Remove a steering wheel on a Farmall H posted by mgolson on June 09, 2008 at 06:55:14:
Put your puller on it and do it up tight to put lots of pressure on. Then when its under max available pressure apply your heat. Should do the trick MTF
