Re: hydraulics
Posted by Steven f/AZ on June 11, 2008 at 09:38:54 from (216.67.213.217):
In Reply to: hydraulics posted by Pete-um on June 11, 2008 at 07:16:57:
Are you looking to do a factory set up like the Super A? If so you would need all the parts from a Super A to do it, including the engine block.
Or you can do it my way:
third party image
third party image
third party image
Or you could use a PTO pump:
third party image
Or you can run a belt off the crankshaft... (this is actually on an H)
third party image
or you could run a shaft drive out the front. (again on an H)
third party image
