Re: Farmall H engine breather tube
Posted by Theman on June 11, 2008 at 10:15:43 from (65.248.77.5):
In Reply to: Farmall H engine breather tube posted by Narrowfarm on June 10, 2008 at 17:18:00:
John, the breather tube was designed to be an air inlet. The filter mentioned below is to keep dust out of the engine. If oil drips while the engine is running you may have a blocked tube in the engine ventilation system or the baffle missing in the valve lifter cover. The path through the engine is as follows: Air from the breather tube crosses the crankcase into the governor housing. It then flows through the small tube from the governor to the front of the head where it travels through a tube over the rocker arm assembly. This tube has a small hole punched in it to remove any blow-by that gets past the valve guides. The air/oil vapor then exits the back of the head and is taken directly into the air cleaner. The brass fitting that is threaded into the back of the head has a small orifice in it that can be blocked by deposits or oil sludge over the years. Also, a previous owner may have discarded the tube leading to the air cleaner altogether - which was the case with my "51H.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
