You are right Andrew – your alternator output voltage is still too high!
You should see a maximum of 14.0 and 14.5 volts. Also after the engine has run a few minutes the ammeter indication should taper off to just a couple amps of charge. (If operated at higher voltages for very long it will eventually cook your battery...)
From your description it sounds like the mitsu alternator is internally regulated. And if it is indeed internally-regulated and you have nothing connected to the alternator aux terminals, there is no “voltage sense” feedback to the regulator. This then auses the regulator think the output voltage is too low. So it boosts voltage to compensate.
You might try this (Note: Do this at your own risk – I’ve not tried it myself!):
1 – Disconnect the battery ground cable (for safety…) then any the wiring to the alternator.
2 – Take an ohmmeter and measure the resistance from each alternator aux terminal to ground. One terminal should have a very low resistance (a few ohms); the other very high resistance (many thousands of ohms).
3 – Connect a new wire between the HIGH resistance aux terminal and the alternator’s output terminal.
4 – Now reconnect the other alternator wiring and the battery ground, start it up and see what happens.
Unfortunately I do not have a diagram for a 10DN (externally regulated) Delco alternator. However I’m sure a quick google search can turn one up….
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
