Re: Alternator question again
Posted by Janicholson on June 11, 2008 at 11:59:19 from (199.17.6.122):
In Reply to: Alternator question again posted by Andrew Z on June 11, 2008 at 10:52:08:
Make sur your Volt meter is accurate. Check a fully charged 12v battery. It should read 12.6 volts if it does, then your meter is OK.
JimN
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
