Strange 460 gas problem????
Posted by jstpa on June 12, 2008 at 06:02:16 from (67.234.132.195):
Hey guys, We are having an intermittent problem on a 460 gas tractor. While raking hay the tractor just shuts off, Pull the choke and it will usually refire instantly and go again, sometimes for hours. Last night just moving the tractor around it shut off, could not get it to refire w/ choke so we pulled the hose loose from the carb to the oil bath,put it back on before we turned it over, then cranked it and it fired right up. The oil bath was taken apart and cleaned out a couple months ago, and the rubber hoses both appear to be clean along with the metal hose going from the oil bath to the carb. Does anybody have any suggestions what could be going on, or what else we could check. Thank you, jstpa
