Re: 1206 pto
Posted by LP gas only on June 12, 2008 at 10:22:40 from (12.11.211.126):
In Reply to: 1206 pto posted by foothill on June 12, 2008 at 10:11:36:
Sounds like your pick up tube is laying in the bottom of the rear end housing. Park it down hill and take the cover off that holds the top link. With a mirror and flashlight you should be able to see if it is missing.
Gary
