Re: Model M still won't run
Posted by ne neb farmall on June 12, 2008 at 14:56:27 from (12.186.41.38):
In Reply to: Re: Model M still won't run posted by Bob on June 12, 2008 at 14:28:55:
Did you replace the fuel line? Have you tried to run it with the fuel cap off to see if that helps? When it stops can you shut off the fuel and remove the float bowl and see if there is fuel in it? If it is empty I would think it is a fuel problem. I always unhook my fuel line from the carb and blow compressed air back through the system till it bubbles in the tank to try and remove restrictions.
