Re: Model M still won't run
Posted by Brownie 450 on June 12, 2008 at 16:00:45 from (216.51.158.151):
In Reply to: Model M still won't run posted by Another Bob on June 12, 2008 at 13:59:33:
This has been suggested before--take the drain plug out of the bottom of the carb & put in a hose/plastic tubing connector. Put a section of clear plastic tubing on the hose barb & hold it up along side the carb- leaving the upper end open. Start the engine & watch what the fuel level does. If it remains at the same level, you probably don't have a fuel delivery problem. However, if the fuel level drops very far, you are having delivery problems. Could be a restriction anywhere in the fuel delivery system.
