Without more details, the rebuild price range could go from $1000 to $2500.
But do you really need a full rebuild? Is the smoke black or gray? Gray smoke comes from burning oil and has a characteristic burned oil smell. This engine is overcarburated with a M carb. If the carb is crapped up, you may be putting way too much gasoline into the engine and getting a lot of black soot, and black dry carbon on the spark plugs. Burning oil will make the plugs black and oily, usually wet looking.
The 300 Utility had a 164 cu in engine, while the 350 had a bit bigger 169 cu inch engine. Your title to this thread made me doubt that you know exactly what you have. The 300 Us were made in 1955 & 1956, but by 1957 the 350 was the model. Before ordering any parts, you need to know exactly what engine you have. To make matters even more confusing, it is possible to swap into the 300 U an engine from the Farmall H at 152 cu inch. It is not quite a direct swap, as some of the external parts from the 300 engine need to be used like the front timing gear cover. Now you need to figure out what some previous owner may have done, or determine that you have an original setup.
The family of engines that I have described all have dry sleeves, but of different bore diameters. There were many options for pistons, some stock options, and some aftermarket high compression pistons. All this amounts to: There is very little likelyhood that you will be doing a stock rebuild. You won't know what you need until you get into it. I had a small 4 cylinder tractor engine rebuilt 2 years ago that went $1000 over my estimated price. It is much cheaper to do careful diagnostics (compression check, cylinder blowdown, etc) and then repair what is needed. But if you got the $$, I am sure that some good shop will gladly accomodate you for a full rebuild.
Any one of the engines I mentioned are mighty tough little engines, and are readily rebuilt. The head with the overhead valves probably needs to go to a cylinder head shop for valve work. I have recently spent $500 on a head rebuild.
Get your details in order, and then good luck with your decisions.
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
