Re: hydraulic control setup
Posted by mkirsch on June 13, 2008 at 05:39:32 from (64.80.108.52):
In Reply to: hydraulic control setup posted by Andrew Z on June 13, 2008 at 03:52:04:
Two 2-spool valves are going to look pretty out of place, too... There just isn't much room to mount stuff on the platform of an H. We had to really work hard to tuck a single-spool valve into a non-obtrusive, yet usable, location on Dad's Super H.
One distinct advantage to the two-two-spool option is that you presumably already have the valves. 4-spool valves are not cheap, even from SurplusCenter.
Personally, I'd mount the loader valves on the loader frame, so that if you ever remove it, the valves go with it. See if you can tuck the 3pt valves under the light bar on the right hand side. That's where we put the single valve on Dad's.
