Re: Re: Re: Farmall M with stuck motor
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by john d on March 14, 2000 at 05:42:13 from (206.141.74.34):
In Reply to: Re: Re: Farmall M with stuck motor posted by TomH on March 13, 2000 at 18:02:27:
As the starter drive, the starter gear, and the ring gear on the flywheel accumulate wear over the years, the starter gear will try to "climb" the ring gear teeth when under heavy load. Then it sticks and jams. If you turn the motor BACKWARDS with that pipe wrench, you likely won't hurt a thing.
Another approach is to loosen the starter bolts, listen for it to release, tighten the bolts, and start it.
Post A Followup
: Re: Re: Re: Re: Farmall M with stuck motor
