Re: F-20 Head question
Posted by Ron in Nebr on June 13, 2008 at 10:00:42 from (66.252.116.221):
In Reply to: F-20 Head question posted by Red Sheep on June 12, 2008 at 18:47:16:
I'd say if you can see clear through to the valve lifters(likely you mean pushrods since the actual lifters are down inside the block), that if you don't have anything that mounts there on your tractor, then you'll need to put short bolts in the holes to seal them up. Probably wouldn't hurt to dab a little permatex or thread sealer on the bolts for good measure.
