Re: Bad VR or bad ground?
Posted by Janicholson on June 13, 2008 at 19:22:29 from (64.83.197.176):
In Reply to: Bad VR or bad ground? posted by mkirsch on June 13, 2008 at 16:06:58:
I say if when you ground the F terminal, even when it starts to kinda work on its own, that the VR is not right. If it were mine I would disconnect the battery, the remove the VR cover, and burnish the contacts with 320 , then blow it out and put the cover back on and try it. Covers affect the magnetism, and need to be on. If still wonkee, Replace. JimN
