Re: Super A problems
Posted by El Toro on June 14, 2008 at 10:24:20 from (205.188.116.73):
In Reply to: Super A problems posted by Allen Young on June 14, 2008 at 09:47:50:
If you only have drip from the tank you probably have rust or dirt or both blocking the flow of gas. Pull the gas line at the carburetor and see if there's a full stream of gas from the line,
be sure to hold a clean container and catch the gas. You may need to pull the gas tank and clean it. Did you hit the mag or distributor with the pressure washer? Pull the cap and check for moisture. Dry it out if it is damp. Hal
