Posted by Owen Aaland on June 14, 2008 at 12:25:43 from (65.174.247.105):
In Reply to: 400 Axle housing posted by Ron Muhlenkamp on June 14, 2008 at 05:43:42:
Ron Muhlenkamp said: (quoted from post at 05:43:42 06/14/08) Thanks
Can the housing be removed without pulling the axle
Ron
No. The inner bearing is retained into the housing with four bolts. You would have to get those bolts out but they are behind the bull gear. You would need to get the bull gear off the axle to gain access to them. Once you have the bull gear off the axle will already be most of the way off the bearing.
With the outer bearing cap off, remove the PTO. Remove the bolt that holds the bull gear on the axle. Remove the washer and reinstall the bolt. Put a spacer between the axle bolts and back the bolt back out again. As you back out the bolt it will push the axle out of the bull gear and bearing.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
