Re: Farmall H engine
Posted by Tom Windsor on June 14, 2008 at 20:00:33 from (205.188.116.73):
In Reply to: Farmall H engine posted by Joe Ambrosio on June 14, 2008 at 18:07:59:
I am having a senior moment and cannot remember his name at the moment...but a member of this list has extensive photos... seems as if it is neblanc--the screen name.
1. take off sheet metal and fuel tank including sheet metal around radiator.
2. disconnect stearing at universal joint.
3. take cap off end of steering unit up front and screw out stearing shaft.
4. take off radiator.
5. Get some blocks under the transmission and jack up so that front wheels about 1/2 inch off floor and block off solidly. (keeping in mind that it is intent to suspend front end from support at transmission)
6. Get a hoist or something and attach to bloister. remove bolts from rail and take out the front wheel assembly. too heavy to handle solo. need lift.
7. take off rails
8. attach lift to engine.
9. remove bolts on the outside that mount engine to transmission
10. remove starter
11 Remove bolt inside the starter hole
12. engine should be free
be careful...some heavy pieces shere.
good luck
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
