Frank, there basically is NO difference between the distillate/kerosene carbs and the gasoline only carbs except for possibly the main metering stem and the fact that the kerosene carb has a drain cock instead of just a plug. Everything else is the same. If you buy a kit for the 45108DA carb, you should get the parts you need, or I can possibly build one for you if you have a good core.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
