Re: Farmall M cylinder diameter
Posted by onefarmer on June 15, 2008 at 11:26:53 from (208.100.200.146):
In Reply to: Farmall M cylinder diameter posted by R McCoy on June 15, 2008 at 11:08:10:
Yes 3 7/8" are still available from many places including right here at YT. I'd stick with the 4" though unless your just not ever going to want max power. The bigger size is made by making the sleeve wall thinner, outside diameter is the same. Either way go with the domed pistons as it would increase fuel efficiency with the higher compression. Save every drop of gas these days!
