Re: Farmall M wide front question.
Posted by Jim R on June 15, 2008 at 19:03:48 from (70.58.241.125):
In Reply to: Re: Farmall M wide front question. posted by Chris NW Ind on June 14, 2008 at 19:49:55:
Thanks for all your responses! I finally got a chance to figure out the front end situation with everyones help. It turns out that the wide front that I bought has the adapter plate with it, which I won"t use, as I want to mount the front end directly under the radiator. I am assuming though that I will still need to drill two holes in the frame to mount the braces to, is that correct? I also assume that I should still use the braces even though the front end isn"t mounted using the adapter plate, is that correct? Thanks again for all your help!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
