Re: black smoke
Posted by Red Mist on June 17, 2008 at 04:34:05 from (72.171.0.146):
In Reply to: black smoke posted by markred on June 16, 2008 at 16:25:54:
markred said: (quoted from post at 16:25:54 06/16/08) 1942 h with new engine kit in it, and overhauled head.. also rebuilt carb from Bates but it wont run smooth and it puts out black smoke, its running rich, the float is set right any other ideas what it might be.i think i need another carb.
Adjust (increase) your closed position float level setting a little (less than 1/8") so that the needle closes on the seat a little earlier and slightly lowers the fuel level in the bowl. I have run into this same problem two or three times - perhaps more so when aftermarket components are used. Or, maybe the float sits a tiny bit lower in today's fuel? Regardless, this cure works consistently well for me. mike
