Re: Re: Re: Re: 806 Power Steering
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Ken T on March 14, 2000 at 14:14:06 from (209.83.58.246):
In Reply to: Re: Re: Re: 806 Power Steering posted by Jim on March 13, 2000 at 19:23:33:
Jim,
You are right about the brakes working with captive oil that was already there from the last time the tractor was ran, but you can still feel the power assist on the brakes when it is working correctly.
The questions you raise are good ones, and since I cannot say that I can give you an honest answer at this time, I plan to run the followning test. It might take a while until I get over to where my tractor is to run the test, but here is what I plan to do:
1. Start the tractor. Do not turn the steering wheel until step 4 below.
2. Drive the tractor straight ahead slowly. Operate TA a few times. Does the TA work?
3. Apply the brakes. Can I feel power assist?
4. Try the steering. Does it work?
Here is what I plan to learn from these tests. If either or both the TA and the power brakes seem to work at first startup, but the power steering does not work, then I will lean toward replacing the manual pump that is attached to the steering wheel. If the TA and the power brakes do not seem to work at first startup, then I will suspect the MCV pump as you have suggested. If the TA and power brakes seem to begin to work about the same time that the power steering starts to work, then I will be more confident that the cause is a bad MCV pump.
Thanks a lot for the suggestion.
Post A Followup
: Re: Re: Re: Re: Re: 806 Power Steering
