Re: Rod bolts
Posted by the tractor vet on June 17, 2008 at 20:21:37 from (76.212.228.133):
In Reply to: Rod bolts posted by jw806 on June 17, 2008 at 04:59:30:
And why are you replacing the rod bolts , they are not the new junk bolts that the new engines are put together with . There are two style bolts used in I H engines one is called a place bolt and the other is called the patch bolt .The bolts you have are the place bolts and get torqued to 50 ft. lbs. the other ones get torqued to 45 ft. lb.
