Re: Clean Super A Fuel Tank
Posted by glennster on June 18, 2008 at 05:30:25 from (75.56.50.121):
In Reply to: Clean Super A Fuel Tank posted by asyrp43 on June 18, 2008 at 05:13:11:
depends on whats inside the tank. if its just dirt and such, you can flush the tank and be good to go. if the tank is rusty and flaking off, i"d put a liner in it. the tank needs to come off to do the liner. you can do the liner yourself, just follow directions on the can. i have done some myself, but the last couple i had a radiator shop do.
