1 – A properly wired 12 volt alternator will NOT overcharge the battery. If it does it's either wired wrong or (long shot...) the alternator voltage regulator is bad. A quick test is stick a voltmeter across the battery terminals with the engine running at governed RPM. If the voltmeter reads between 13.5 and 14.5 volts the charging system is working fine.
2 – From the behavior of your battery (uses water, cranks slow, trickle charger runs continuously) it has reached the end of its life. Time for a new battery!
3 – Good chance leaving the trickle charger on the battery over the winter hastened its demise. Unless the charger is properly calibrated and temperature compensated (and the cheap ones are not) it will continually overcharge battery and slowly boil the life out of it. Better to simply let the battery sit over the winter and then once every 2 – 3 months put a charger on it overnite to top it back up.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
