460 Utility tel a depth
Posted by Gary in Mozarks on June 18, 2008 at 15:41:53 from (66.43.47.111):
I finally found a section on the teladepth in the 460 IT manual and it says the unit should go "off pressure at each end of the 90 degree lever range. Mine isn;t going off pressure. I removed the guard so I could move the lever more than 90 degrees and I have pressure through about 140 degrees of movement of the range lever. Anyone have experience with these things? Also the rock shaft lifts if I move the range lever forward and down. Is that correct or do I have the hoses reversed? Thanks in advance
