Posted by John T on June 20, 2008 at 05:35:08 from (66.244.97.31):
In Reply to: super c VR issues posted by mazemeister on June 20, 2008 at 03:16:36:
Maze, I dont think its any third brush adjustment problem, cuz if she charges that well with a dead grounded Field that says the genny (including wherever its third brush is set) is fineeeeeeeee PLUS the gennys ground is fine. I agree with my buddy the Bob M, before tossing the VR make sure it has its own good ground by jumping its case/frame/metal to a good ground n see if charge improves??? (also check n clean the VR's F terminal to gennys FLD post wiring for a loose or resistive connection) If not you may be able to non abrasively as possible clean/buff/polish the VR's field control relay contacts cuz they may be burned or carboned n resistive, worth a try (grounding and cleaning).....
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
