Re: super c VR issues
Posted by teddy52food on June 20, 2008 at 06:10:47 from (209.237.111.169):
In Reply to: super c VR issues posted by mazemeister on June 20, 2008 at 03:16:36:
You may try using a voltmeter to set the voltage before replacing the regulator. With the cover off, put a little pressure on the points next to the field terminal. If the voltage and amps increase tighten the spring tention until you get about 7&1/2 volts. Check again with the cover on , it may change a little.
