Re: newbie wants to fix up IH 350 Utility and Super A
Posted by Janicholson on June 20, 2008 at 06:42:35 from (66.173.50.123):
In Reply to: newbie wants to fix up IH 350 Utility and Super A posted by newground on June 19, 2008 at 16:19:16:
Two nice units to make nice.
Though the manual steering system on the Utility is somewhat fragile, and "hard to steer" is an understatement, The PS unit is pretty robust if maintained. Parts for the steering are either rebuilt locally, or found used/good. We have a well used 350U with PS, and though currently not as tight as new, it does work well. I was driving it into a farm we owned in the winter through a puddle at 12 MPH when the RF tire broke through the ice. It twisted so hard on the RF tie rod, that the steering arm on the right side of the Box, snapped in half. (exciting) We welded it back together, and it is still there. No gears broke, nor parts bent in the event, so I think they are intrinsically OK. JimN
