Re: sand blasting with a pressure washer
Posted by dhermesc on June 20, 2008 at 07:35:42 from (24.248.193.103):
In Reply to: sand blasting with a pressure washer posted by Dancbtmkr on June 19, 2008 at 16:36:39:
Unless you are going to go back with automotive paint I wouldn't bother trying to strip all the old paint off with a sand blaster. Use (rent) a good power washer (3000 PSI or so) to clean things up and peel off any loose paint then lightly sand the old paint (and sand out any surface rust) on the sheet metal. Its stuck to the tractor for 50+ years and makes a good "primer" for the new impliment paint.
The castings need to be clean (especially around your leaking seals) and free of all contaminates the paint will stick them without even sanding (at least in my experiance). Their rough surface aids in the paint adhering.
As mentioned below the sand gets into everything and you're still sanding to stay ahead of the rust.
