Re: super c VR issues
Posted by Bob M on June 20, 2008 at 10:50:11 from (151.190.254.108):
In Reply to: Re: super c VR issues posted by mazemeister on June 20, 2008 at 09:44:57:
I agree - sounds like the VR relay points have very high resistance. Or possibly there's an open circuit (like broken jumper braid?) between the movable VR relay armature and the connecting circuit.
You might try polishing the VR relay contacts again (use an ignition point file or about 200 grit standpaper). Also look for a broken conductor somewhere between the VR relay armature, its fixed contact and the VR field resistor (located under the regulator base).
At this point however I think you'd be money ahead to simply replace the regulator!
