Re: W9 weight and width
Posted by glennster on June 20, 2008 at 18:18:58 from (68.60.242.156):
In Reply to: W9 weight and width posted by KRUSS1 on June 20, 2008 at 10:00:22:
the weights for my w-9 are around 200 lbs each. if the tire are loaded, add 900 to 1000 lbs per tire depending on the chloride mix. figure an aditional 2400 lbs to be on the safe side to add to the weight cnks gave you. just guessin, i'd use 8000 lbs loaded as a ball park.
