574 hydraulic flow
Posted by jeef on June 21, 2008 at 15:33:01 from (12.186.80.1):
I have fouund several diffrent sources with several diffrent answers to this question.
Can anyone tell me the actual flow of the hydraulic system on a 574?
I purchased a valve that will flow 15 gpm. And the information I had at that time said the tractor flowed 11 gpm.
My concern is I keep hearing the reief valve opening on the tractor while operating the loader, I was concernedd that it may be building pressure in front of the valve causing the system to become restricted. It is just a guess.
With the new valve the loader operates much slower than it did before. I do however know that the raise lower and the tilt is switched on the valve. So I have to fix that somehow.
