Re: Super H Steering
Posted by mkirsch on June 21, 2008 at 20:07:06 from (67.240.251.254):
In Reply to: Super H Steering posted by Greg 2010 on June 21, 2008 at 18:28:51:
The gear is only part of the problem. A little bit of wear in several spots will result in a large wobble. The bushings in the front bolster are probably the main culprit. Top bushing is fairly simple to change.
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
