Re: LP Gas Fueling
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by medfarm on March 14, 2000 at 18:55:49 from (209.162.39.44):
In Reply to: LP Gas Fueling posted by Dick Kline on March 14, 2000 at 16:48:17:
Dick
We have a larger trailer mounted LPG tank which is used to run the weed and grass burner.As the previous post suggested, a special hose with the proper connections is needed to connect the larger tank to the tractor tank. The air bleed screw on the tractor tank needs to be opened to allow the tractor tank to fill. The larger tank needs to have a WET LINE in order for LPG to transfer. The vapor pressure of the large tank will force the liquid to the tractor tank. The wet line is a pipe which extends to the bottom of the large tank.
Ray
Post A Followup
: Re: Re: LP Gas Fueling
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
