H Battery Box Bolts
Posted by Doug Kieta on June 22, 2008 at 06:36:30 from (97.82.24.61):
The battery box on my H has long slots that allow the box to slide out from underneath the fuel tank for battery removal. What type and size of bolt is used to fasten the box to the bracket on the tractor frame? I assume it must be a carriage bolt, and that the square shank beneath the head fits in the slot to prevent the bolt from turning when being tightened. Is this correct, or did IH use some other special fastener? If correct, what size bolt is required?
Thanks for the help.
