Posted by ScottyHOMEy on June 22, 2008 at 06:55:04 from (71.241.211.194):
In Reply to: A clutch posted by HENRY E NC on June 22, 2008 at 06:01:35:
Check and adjust the free-play on your pedal first. If the bearing is bad, it will be noisy when it engages. Generally harmless in the immediate term, but it wears harder on the clutch fingers.
Also, there's nothing real unusual about what I call the "Farmall Grind." On unsynchronzied trannies like yours, it is considered normal to have to hold the clutch pedal down for a second or two (or three) to give the shaft time to quit spinning and be able to get it into gear without making any noise. And that'sjust to strt from a stop. If you're gettin' ideas bout bein' ble to shift on the fly from one gear to another with no grinding you're gin' to ne to grow one more arm. This arm should be on your left side so that you can operate the shifter while adjusting the throttle in the appropriate direction for the shift up for downshifts, down for shifting up, and you can still expect some grinding and kerchunking until you get good at it. Having two arms on the left will leave your right arm free to pay attention to the direction of travel and adjust as necessary.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
