Re: A clutch
Posted by JimB2 on June 22, 2008 at 09:25:18 from (99.241.179.24):
In Reply to: A clutch posted by HENRY E NC on June 22, 2008 at 06:01:35:
Hi Henry, If clutch adjustment doesn't fix the problem then if the A is like the SC the problem could be the pilot bearing in the flywheel. On a SC this is only a bronze bushing and after time the clutch crud and dried up grease will keep the transmission shaft spinning with the clutch depressed. Unfortunately on the SC there was no method to lube this bushing from the inspection plate. Only solution was to split and replace.
Looked at parts on caseih.com and C-123 and this is the part: 364527R2 BUSHING BUSHING, clutch pilot, optional with 399135R91.
JimB
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
