Re: brush chopper slippage
Posted by Janicholson on June 22, 2008 at 10:25:15 from (64.83.197.176):
In Reply to: brush chopper slippage posted by Dellbertt on June 22, 2008 at 06:06:09:
Assuming it has the band type IPTO,and the lever is not bent or linkage out of spec.
There is a mark on the lever base (manual)
that is midway from locked on, to locked off with the button on the handle.
In this position, adjust the bands (seperately) (under the little peanut shaped cover on the top)
until each is tight enough to prevent rotating the shaft by hand. Then loosten each about one half turn. This will (should) make it free to turn by hand. It should also make it drive, and brake correctly. Make sure you click the lever latch in either position. Running it W/O latching will cause slipping. Linkage slipping, and bent rods are also issues to wach for. Good luck. JimN
