Posted by Janicholson on June 22, 2008 at 10:33:46 from (64.83.197.176):
In Reply to: Re: back firing posted by lbm on June 22, 2008 at 10:13:12:
Put a different condenser in the distributor. try it. Use a known good coil. Try it.
Next, Pull the plugs. Turn the engine untill #1 pumps air out past your finger. Then put a piece ov copper wire about 8" long in the #1 hole, and turn the engine with the fan till the wire stops moving up. This is TDC. The timing mark will also be aligned at this point. The rotor should be pointing to the 1:30 position. The wire attached there is #1 plug wire. If it is not, The Engine may have slipped time. JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
