Re: Hugh McKay's Fault!
Posted by Roger46 on June 22, 2008 at 17:21:30 from (69.58.159.80):
In Reply to: Hugh McKay's Fault! posted by Allan In NE on June 22, 2008 at 03:16:14:
Allan, I just sharpened the blades on my Woods 503 mower and the blade bolts were left hand. You should be able to tell if they are left or right hand by the direction the blades turn, since the idea is to keep the bolts from unscrewing when they turn. The problem I had was loosening the bolts while laying on the garage floor and reaching under the mower. Then the next problem was torquing the bolts to 200 ft-lbs (per the manual) while laying on your side reaching under the mower. Roger
