Re: brush chopper slippage
Posted by Bob Kerr on June 22, 2008 at 20:54:47 from (64.12.116.73):
In Reply to: brush chopper slippage posted by Dellbertt on June 22, 2008 at 06:06:09:
If your chopper is clutched with a disc type clutch, I have good luck if I clean the disc out. They get dust in them and the dust acts like ball bearings. I losened up the clutch adjustment till it slips just a tiny bit. Start it up and while it is on the ground running at idle(and please BE CAREFUL!)pour water (or squirt in brake cleaner) down in between the friction material and plate. Stand to the side when the stuff slings out! let it slip some more to heat it up to get the water or cleaner dried out and shut her down, then tighten up the adjustment. I did this on an old Ford bushog and it worked slick as a whistle. Some guys will drill a hole through the plates and put in a couple brass bolts if the friction material is gone.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
