Re: 3 PTO'S
Posted by Hugh MacKay on June 23, 2008 at 01:30:16 from (216.208.58.146):
In Reply to: Re: 3 PTO'S posted by Mark from WI on June 22, 2008 at 19:05:59:
Mark: If you ever check into the specs on do's and don'ts on 66 series tractors, they tell you not to use 540 rpm PTO for applications over 100 hp. If you read my responce to Gary below, my operator firmly believed it was 1066 PTO slipping and not the 770 forage harvester slip clutch.
Not many folks remember this one either, "IH also warned operators not to use 1066 and 1466, equipped with duals, for maximum drawbar pull in the 3 lowest gears."
