Re: Request an opinion on my differential shaft
Posted by Hendrik on June 23, 2008 at 02:16:34 from (194.53.253.50):
In Reply to: Request an opinion on my differential shaft posted by P and R Pete on June 21, 2008 at 19:13:38:
I had the same problem with my Super A. Could only find a speedi sleeve for the part of the shaft that goes in the axle housing and not for the end of the shaft that goes in the differential case. Polished the end of the shaft that goes in the differential case. Because it is slightly undersize, I tweaked the spring in the seal a little bit. The spiral spring which helps keep the lip of the seal against the shaft can be taken out and shortened (approx. 1/8 of an inch). (This spring may seem endless at first but one end is slightly tapered en screws into the other end to obtain its annular shape.)
HTH. Hendrik
