super C VR update
Posted by mazemeister on June 23, 2008 at 07:18:04 from (24.188.81.230):
Thanks for all your help guys- I ended up pulling the VR and filing the contacts. Just needed more elbow grease i guess. finally got so an ohm meter measuring from the F terminal to ground would read 22 with the points held open and less than 1 with them closed. works better now- only wants to charge about 2A, but at least it's charging.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
