Re: Problem with M 12 volt conversion
Posted by Bob M on June 23, 2008 at 11:28:52 from (151.190.254.108):
In Reply to: Re: Problem with M 12 volt conversion posted by Brad34 on June 23, 2008 at 10:10:52:
Brad - The "no crank" condition is most likely a bad battery cable connection or worn starter switch. Other (long shot...) possibilities are a bad starter or jammed starter bendix.
Not to worry: You didn't hurt a thing cranking the engine with nothing connected to the #1 and #2 alt terminals! Only thing that would happen had the started is the alternator would not have charged...
