Re: mag pull switch
Posted by El Toro on June 23, 2008 at 12:26:57 from (205.188.116.73):
In Reply to: mag pull switch posted by Brad in Colockum on June 23, 2008 at 06:29:42:
You could probably use a toggle switch and most electronics store should have them. Hal
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
